Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
Thread: stuck in d mode. ..... help
  1. #11
    Member Gallo's Avatar
    Join Date
    Feb 2015
    Tallinn
    Posts
    76
    Default
    Quote Originally Posted by ginner1973 View Post
    Help please my Dino is stuck in d mode it wont go back into neutral even when turned ignition off then on...please help ive checked fuse and solenoid contacts..
    today I got smarter!
    I had same thing, D is on and does not go to neutral, solenoids checked, all possible electrical wires checked, still nothing.
    Guess what!=!=!=!
    BATTERY was dead! It had some small amount of power in to be able to give out something...but not enough power to change gears from D to Neutral or any of them.
  2. #12
    Senior Member
    Join Date
    Aug 2012
    london
    Posts
    107
    Default Flat Battery
    Nothing to do with all those extra electricals?
  3. #13
    Join Date
    Feb 2015
    Tallinn
    Posts
    76
    Default reply
    Quote Originally Posted by dndom View Post
    nop absolutely nothing!
  4. #14
    Junior Member
    Join Date
    Sep 2017
    Hanoi, Vietnam
    Posts
    2
    Default Same problem but in reverse
    I am in the same problem as him but in reverse: Iím stuck in N and canít get into D at all
  5. #15
    Junior Member JOHNVOLT's Avatar
    Join Date
    Jan 2018
    GREECE
    Posts
    2
    Default D GEAR ON AND CANNOT START ENGINE
    I own DN 01 Almost a year now...im doing some ''tricks'' i ve learn all this time when the dn stucks on D mode....try one off the following one at a time , cause is not always for the same reason when it does this problem....a) shake the bike a bit for the htf pistons to be in the right place inside b) have press on ingition button when you turn on the key c) take off the battery poles for 15mins D) charge your battery so that the ecu has enough power to make a full check when u turn on the key....when i try one of the above i always have a positive result and i always start the bike...remember always to turn the mode to ''N'' before u turn off the bike
  6. #16
    Senior Member Gizmo's Avatar
    Join Date
    Jan 2013
    Jacksonville, Florida USA
    Posts
    409
    Default
    Quote Originally Posted by JOHNVOLT View Post
    I HIGHLY endorse the habit of switching to 'N' prior to shutting off the bike ... seems to alleviate potential problems!
    2009 Honda DN-01
    2015 Yamaha R3
  7. #17
    Join Date
    Jan 2013
    Posts
    409
    Default
    Quote Originally Posted by xavier.nguyen287 View Post
    Just a few thoughts: check the oil level in the bike or maybe change the oil if it's been a while. Shake the bike to 'free up the oil.' Plus verify that the battery is putting out enough juice to activate the HFT electrical system. The HFT sensor maybe bad.
    2009 Honda DN-01
    2015 Yamaha R3
  8. #18
    Junior Member
    Join Date
    Oct 2017
    Poland
    Posts
    2
    Default problem "D" ; "N"
    I had this!
    - I have canceled the alarm-it helped for some time
    - the old battery has blocked it
    - I replaced it with a new battery
    - motorcycle computer reset- 3 errors (servis)
    it helped
  9. #19
    Junior Member
    Join Date
    Feb 2018
    france
    Posts
    1
    Default
    hello I had the same problem as you but sorry if my english is bad, I'm french and I translate my word with internet
    impossible for me to leave the D mode
    I thought immediately of a problem of sensor and after my researches I changed three pieces the least expensive
    here are the 3 pieces:
    number 20 :
    https://www.partzilla.com/product/honda/37240-P13-013
    number 22
    https://www.partzilla.com/product/honda/38400-MEH-003
    number 23
    https://www.partzilla.com/product/honda/38500-MEH-003
    since that day I have no problem
    I have already done 10,000kms since the change
    after I do not say it's THE solution but for me it has solved the problem
    very simple to change and not very expensive, just a screw to dismount and shoot on the sensor
  10. #20
    Junior Member friesentom's Avatar
    Join Date
    Nov 2012
    Germanny
    Posts
    14
    Default
    Hallo hatte auch das Problem hatte nur diese teil getauscht
    https://m.ebay.de/itm/Oldruckschalte...item28302a4d34
    An dem schalter ist folie drin und die macht probleme habe schon 6 Jahre kein Problem mehr
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
