Results 1 to 10 of 10
Thread: Hi
  1. #1
    Junior Member
    Join Date
    Sep 2017
    Location
    Nuneaton England
    Posts
    1
    Default Hi
    Hi from Nuneaton England.
    I would appreciate any advice on how to make my ride more comfortable as I'm getting on a bit and it's killing my lower back, any advice appreciated cheers.
  2. #2
    Senior Member
    Join Date
    Apr 2011
    Location
    Sarnia, Ontario
    Posts
    102
    Default
    Your fist stop is a driver's back-rest. There are a few available. Alternatively, you can get a completely new seat - that has a different 'Butt-Print'.
    I found the same - my lower back suffered the first couple of years of riding the DN-01
    Welcome to the group.
  3. #3
    Senior Member Gizmo's Avatar
    Join Date
    Jan 2013
    Location
    Jacksonville, Florida USA
    Posts
    409
    Default
    Quote Originally Posted by DNSarnia View Post
    I use a rider/driver back rest ALL the time when I ride, it helps A LOT especially IF you ride any distances. (Won't ride without one on the Dino!)
    2009 Honda DN-01
    2015 Yamaha R3
  4. #4
    Junior Member
    Join Date
    Sep 2012
    Location
    Coventry, UK
    Posts
    10
    Default
    Hi - I found that to improve how my back feels after a ride is to ratchet the rear suspension pre-load to near maximum - too soft a ride gave too much feedback - sounds counter-intuitive, but it worked for me. Also, changing posture to sit as upright as possible whilst tensing stomach muscles now and again does help.
  5. #5
    Join Date
    Oct 2016
    Location
    Lisbon
    Posts
    96
    Default
    I only know UTOPIA, are there any others?
  6. #6
    Join Date
    Mar 2017
    Location
    Australia
    Posts
    37
    Default
    I don't know what or who you ride with, ie what if anything is on the passenger seat.
    I ride solo and have a Cortech "soft" bag attached to the passenger seat.
    It was tricky to fit but works well.
    As a test I made up a "cushion" to attach to the front edge of the bag which pushes against my lower back. You could try different sizes of foam to see what might work.
    To be honest I haven't actually tried it out yet on the road (only in the garage where it seemed quite comfortable), but may do soon if the weather clears.
    I think most lower back pain is caused by bending the lower part of the spine in a semi-permanent fashion when we ride. ie we tend to stretch forward to the bars, which as anyone who has ridden sports bikes as I have for many years would know, it causes "discomfort" and semi numbness in the lower back and shoulders, arms and hands.
    The more upright you ride and the more relaxed the arms the more comfortable you are.
    Personally I find the dino quite a comfortable setup with the boards, swept back bars and roomy seat.
    I had a couple of bikes to which I fitted backrests and found them to be too inconvenient getting on and off and I could never quite get them in the sweet spot.
    Another option might be to try a "kidney/weight lifting belt when you ride as they help to keep your back straight.
    Anyways, a couple of low cost alternatives to try before lashing out hundreds of dollars on an expensive "maybe" seat
    good luck with your search
    Pete
  7. #7
    Member Rus's Avatar
    Join Date
    May 2015
    Location
    Russia Perm
    Posts
    82
    Default
    I use the back of the pilot, my height of 175 cm is comfortable
    http://www.utpr.com/crossover.html
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    Everything will be fine
  8. #8
    Join Date
    Jan 2013
    Location
    Posts
    409
    Default
    Quote Originally Posted by Rus View Post
    Looks GOOD!
    2009 Honda DN-01
    2015 Yamaha R3
  9. #9
    Senior Member
    Join Date
    Aug 2012
    Location
    london
    Posts
    107
    Default Back support.
    Similar to 'Overthehill', a Givi plate and box bolted to the pillion seat with a foam filled computer bag bolted to the front for cushioning. Use this system on all my upright bikes when solo. Tried sport belts with limited success.
  10. #10
    Senior Member
    Join Date
    Apr 2011
    Location
    Sarnia, Ontario
    Posts
    102
    Default Utopia is the kind I got....
    Quote Originally Posted by spitfire_pt View Post
    This is the one I got. There is a set screw at the bottom behind the backrest, that is adjustable. It moves the backrest forward and back. With a little practice, and a throttle lock, I am able to adjust the position while on the road.... it helps a lot to change your posture every once in a while.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
