Honda DN01 Forums -  International DN01 Motorcycle Community Forum
Old 07-11-2017, 01:53 AM   #1
whitehawk
Default Radiator damage
Just had to replace the radiator after coolant leak and engine overheating.
I was on the motorway filtering through queuing traffic on a very hot day (for the UK), when the temperature warning light came on and then the bike went into neutral - engine still running but no gears, so had to coast to the side.
Coolant had clearly leaked from the back of the radiator around the center area.
Garage has replaced the radiator (400 just for a new radiator!!) and the cause of the problem surprised me - many of the fins on the old radiator were badly corroded and damaged which caused the radiator to overheat (not the engine at this stage). This overheating caused it to warp very slightly which brought some of the water channels into contact with the spinning electric fan on the back of the radiator.
The fan then took a small chunk out of the water channels which of course lost most of the coolant.
I had been intending to fit an extender on the front mudguard to help keep the radiator clear of muck from the road, but this is now a higher priority to help prevent the same happening again.
Fortunately looks like no engine damage.
whitehawk is offline   Reply With Quote
The Following 5 Users Say Thank You to whitehawk For This Useful Post:
dndom (07-11-2017), Gizmo (07-11-2017), senior (07-11-2017), som2002 (07-11-2017), spitfire_pt (07-11-2017)
Old 07-11-2017, 01:38 PM   #2
Gizmo
Senior Member
Gizmo's Avatar
Default
Need to inspect the bike more often for preventative maintenance/damage other than just scheduled maintenance.
__________________
2009 Honda DN-01
2015 Yamaha R3
Gizmo is offline   Reply With Quote
Old 07-12-2017, 02:06 AM   #3
whitehawk
Default
>>Need to inspect the bike more often for preventative maintenance/damage other than just scheduled maintenance.<<
Indeed. Every time I washed the bike I tried hosing dirt out of the radiator with a low pressure hose, but there was an area in the middle that could not be cleared with normal pressure, and a high pressure washer would have damaged the fins. If I'd spent the time clearing it manually bit by bit with an appropriate small tool then I may have noticed the poor condition of many of the other fins.
Expensive lesson learned.
Any suggestions for best place to get a front mudguard extension? I've seen a couple on ebay.
The Following User Says Thank You to whitehawk For This Useful Post:
Gizmo (07-12-2017)
Old 07-12-2017, 02:42 AM   #4
spamer80
Senior Member
spamer80's Avatar
Send a message via ICQ to spamer80 Send a message via MSN to spamer80 Send a message via Skype™ to spamer80
Default
I have one from eBay. Works fine. Not perfect, but fine.
Next time use http://www.partzilla.com/parts/searc...TOR/parts.html
$353 vs 400 is worth to wait imo. But be careful, some parts (like fairing) on US and EU models are incompatible.
spamer80 is offline   Reply With Quote
The Following User Says Thank You to spamer80 For This Useful Post:
whitehawk (07-12-2017)
Old 07-12-2017, 06:59 AM   #5
Gizmo
Senior Member
Gizmo's Avatar
Default
Glad I don't have to put up with this in Florida!
__________________
2009 Honda DN-01
2015 Yamaha R3
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Copyright 2011 , All content is property of DN-01.net All Rights Reserved. The opinions and posts on this site do not neccesarily reflect those of the site owners or operators.
DN-01 and Honda rights are property of Honda Motor Company.
