Honda DN01 Forums -  International DN01 Motorcycle Community Forum
Old 06-30-2015, 01:54 AM   #11
DammmDel's Avatar
Default
I've had the oil light come on twice, both times was because I started the bike when it was on an incline. After checking the levels n usual things i rode it 3 miles to my local Honda dealer, After speaking to them they assured me it was because of the incline and the oil level at that time, when I got back on and started it (with the stand down) the oil light went out and stayed out. If your oil light is staying on then it has to point to a sensor or something similar as you have done all other checks. Sometimes it has to be maindealer even if its just to reset stuff.. Let us know buddy
DammmDel is offline   Reply With Quote
Old 06-30-2015, 03:00 AM   #12
Senior Member
Default
Had a sticking oil level switch cause fault code 14, if my memory's correct, couple of years ago. It cured itself.
dndom is offline   Reply With Quote
Old 06-30-2015, 07:15 AM   #13
Default
I have had this happen twice. It was caused by parking on an incline. I parked on a flat surface and disconnected the battery to reset the ECM.
That fixed the problem.
bhamrider is offline   Reply With Quote
Old 06-30-2015, 10:49 AM   #14
jdunker
Default
Well, I came to work today with the intention of taking the bike to the shop later in the day. I tried one more time this morning to stand the bike upright and start it after it sat for a few minutes. Surprise, it's no longer blinking OIL.
Thanks for all of the responses.
jdunker is offline   Reply With Quote
Old 06-30-2015, 03:03 PM   #15
Senior Member
Gizmo's Avatar
Default
CONGRATULATIONS!!!!
Gizmo is offline   Reply With Quote
Old 07-09-2015, 10:01 PM   #16
Senior Member
zebra03's Avatar
Default
We have good people here at this forum .
__________________
2009 Honda DN-01
2007 Suzuki DR650SE
2003 Honda Reflex
2013 Suzuki Burgman 650
zebra03 is offline   Reply With Quote
Old 05-23-2016, 10:51 AM   #17
Senior Member
Gizmo's Avatar
Default
Had the 24K mile maintenance check/work performed by a Honda dealership @ 21,500 miles because NO service had ever been done on the bike even before I bought the bike @ 8000 miles, I believe. Yesterday, 1000 miles after Honda's maintenance, 2 hours into a 4 hour ride, my Dino clock started flashing "OIL" after a quick rest stop. I ALWAYS start my bike upright, side stand up. I checked the oil level ... higher than normal (above the topmost mark). I had noticed this prior after getting the bike back from the Honda shop whenever I had checked the level. Broke out the Owner's Manual, followed the "reset" procedure ... would not reset back to the clock. I then drained the oil and refilled to the proper level using the bike's "dipstick" as an indicator. The result was ALMOST 15 ounces of EXTRA oil left over (just about a pint of oil)! Someone had OVERFILLED the bike @ the Honda dealership. I also removed the positive lead on the battery ... just because it might have been an indicator glitch. Re-attached the lead and started the bike .... "OIL" flashing still! I took the bike on a short 3 mile ride, stopped, turned off the bike and then came back about 5 minutes later ... clock NOW works! I don't know IF it was the excess oil or resetting the computer that FIXED the problem! I sure as hell didn't want to have to buy a new oil level sensor OR take it to the shop ... that cost MONEY!!
Old 06-18-2017, 08:41 AM   #18
Default
Thanks Spamer80. I was out on a ride two weeks ago, It was while rounding a long curve, that my clock turned to "OIL". I noticed it right away. Having never read this particular post, it was new to me, and right away figured that it was either very low, or that going around the corner, the sensor had mis-diagnosed the low-level condition. After pulling into a gas station, and physically confirming that all was well and good with my oil, I pulled out my 'dumb phone', and I googled 4 words: Honda DN-01 OIL Display. Up popped this thread, I stood my bike upright, kicked up the kickstand, and never looked back - thanks for that. My heart stopped pounding loudly.
Quote:
Originally Posted by spamer80 View Post
Detecting condition of the oil level
When the ignition switch is turned ON, the TCM confirms that the oil level switch is ON or OFF to detect the engine oil level.
Oil level detection is only performed at the moment when the ignition switch is turned ON and the sidestand is retracted
(sidestand switch is closed). The condition under which the oil level is detected is that the oil temperature i s so c (120 F)
minimum when the ignition switch is turned OFF and it has been four minutes or more since the ignition switch has been turned OFF and the current oil temperature is 35C (95F).
The TCM cannot detect the oil level if the engine is started with the sidestand lowered.
If the motorcycle has been repeatedly ridden for 2,500 km without detecting the oil level, "OIL" will be indicated in the trip meter as a warning to the rider .
DNSarnia is offline   Reply With Quote
The Following 2 Users Say Thank You to DNSarnia For This Useful Post:
Gizmo (06-19-2017), spamer80 (06-22-2017)
Old 09-06-2017, 12:05 PM   #19
MDS77
Junior Member
MDS77's Avatar
Default Service manual Solution
This works for me.
Click image for larger version
MDS77 is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Copyright 2011 , All content is property of DN-01.net All Rights Reserved. The opinions and posts on this site do not neccesarily reflect those of the site owners or operators.
DN-01 and Honda rights are property of Honda Motor Company.
