Results 1 to 8 of 8
Thread: convert foot brake to handle bar ?
  1. #1
    Member JG122's Avatar
    Join Date
    Jul 2011
    Location
    New Jersey
    Posts
    57
    Default convert foot brake to handle bar ?
    I've seen that some Dino folks have taken the parts from a modern Silver Wing and put them on the left handle bar...
    anyone here done this conversion ?
  2. #2
    Junior Member
    Join Date
    Apr 2011
    Location
    SW Florida USA
    Posts
    21
    Default
    Most riders are used to working the left lever (Clutch) as a means to slow or keep the bike from moving. Especially when using two feet to manuver the bike around, not allowing to keep one foot on the brake pad. This would make the Brake conversion a smooth transition. Moving the bike with your feet and holding on to the throttle while in drive caused me to surge forward abruptly and almost run into a parked vehicle, very Scary.
    I would really like to do the conversion on my bike, please someone give us some ideas.
    1980 Honda GoldWing GL1100i Black / Gold
    2009 Honda NSA700A DN-01 Candy Glory Red
  3. #3
    Join Date
    Jul 2011
    Location
    New Jersey
    Posts
    57
  4. #4
    Senior Member spamer80's Avatar
    Join Date
    Jan 2012
    Location
    Saint-Petersburg, Russia
    Posts
    282
    Default
    Well, I'm the one who changed the foot brake to handle bar. Feel free to aks your questions. As for me, it's very useful.
  5. #5
    Join Date
    Jul 2011
    Location
    New Jersey
    Posts
    57
    Default
    Quote Originally Posted by spamer80 View Post
    excellent !
    I did not know it was you
    would you be able to list all the Honda part numbers involved ?
    and what the whole job cost you ?
  6. #6
    Join Date
    Jan 2012
    Location
    Posts
    282
    Default
    It wasn't me actually, but I was one of the guys who did it. The whole job I did by myself so I can't say correctly how it will be cost. I can't probably list absolutely all the parts, but the whole pedal, hose between pedal and ABS and rear master cylinder should be removed. Sounds terrible but it's pretty easy. The worst part is to make ABS work again after liquid draining. Later I will try to search part numbers using Honda EPC for Motorcycles. Also I can give you a photo of removed parts. Then you will take a rear brake from Silverwing, make some plastic cut-off from the left handlebar (about 1-2 cm.) and install it. I have also installed the armored hose, and front brake from Silverwing too, to make a similar look. It was about $200+$200+$400 include shipping to Russia.
  7. #7
    Junior Member
    Join Date
    Dec 2018
    Location
    Surrey, UK
    Posts
    6
    Default
    Old thread but exactly about what I wanted to ask as I am intending to convert to handlebar brake on LHS, just like a bicycle.
    Seems to me you should be able to use a Clutch master cylinder just connected to ABS module where the foot brake master cylinder used to be. However, 2 questions occur to me:-
    1. What bore size of Master Cylinder?
    2. Will a clutch M/C matching the brake on the RHS fit over the switch?
    The original foot Master Cylinder is 15.87mm (5/8") but would this be suitable for hand operation, or would a smaller one be more suitable to apply more pressure? How much force does a hand exert when pulling on such a lever compared to a foot rotating around the ankle, pushing on a pedal? Part of that will be determined by the mechanical leverage ratio of the levers, but also the bore sizes of the M/Cs. So what size will work best?
    I have experienced issues on other bike projects where the LH switch interferes with the operation of the clutch lever. Does the size of the DN-01's switch cause such a problem if a typical clutch M/C that matches the RH brake M/C is used?
    Those who have done this conversion will undoubtedly know so would appreciate their feedback.
  8. #8
    Join Date
    Jan 2012
    Location
    Posts
    282
    Default
    Not sure. Looked all the same for me. As I`ve told, used the Silverwing ones.
    You forgot that between brake cylinder and caliper there is ABS box installed. So it changes the pressure too. The setup I used for years was more than enough for me.
    All other questions are a bit strange for me. Not sure what you mean but it worked good. No contact with other controls, just some cut-off in plastic on left handlebar cover.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
