Results 1 to 5 of 5
Thread: Transmission trouble
  1. #1
    Junior Member
    Join Date
    Jul 2019
    Location
    Hornchurch
    Posts
    2
    Default Transmission trouble
    Hello all. I use my DN01 for my daily commute which now has over 34k miles on the clock. I parked the bike last Wednesday evening but come Thursday morning it is refusing to start. When you turn the key to fire her up the bike normal engages nueteral however she is now showing D on the display. As a result she will not start. My local Honda dealers where I bought the bike are not able to offer any advice other than it might be an ECU problem. Has only experienced anything like this in the past? Would anyone know if resetting the ECU is something that can be done by a home mechanic? Any thoughts appreciated. I need the bike back asap as I hate public transport!!!!
  2. #2
    Senior Member
    Join Date
    Aug 2012
    Location
    london
    Posts
    122
    Default
    Did you switch it to neutral before switching off?. Try toggling the switch and checking the solenoid behind the R/H plastic engine cover.
  3. #3
    Junior Member
    Join Date
    Jul 2019
    Location
    Hornchurch
    Posts
    2
    Default
    Quote Originally Posted by dndom View Post
    Thanks I will give that a try and let you what happens.
  4. #4
    Join Date
    Nov 2011
    Location
    aussie land
    Posts
    97
    Default
    hold the gear select switch on and turn the ignition on at the same time.
  5. #5
    Junior Member
    Join Date
    Jan 2019
    Location
    Texas
    Posts
    16
    Default
    A13 don't worry it is just a random pain in the butt that happens from time to time with this bike. There is lots of tips on how to get the bike going on this site I'm sure one will work.
    I do not know of anyone that actually had a "transmission failure" that needed a new transmission.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
