foxdie
Hi folks, back in 2014 I made the following post before buying my Honda NSA700 / DN-01. In the last 2 years of ownership I've learnt a lot about these bikes and this post has made it to the top of search engine, so I'm going to edit this post contents to better reflect ownership.
If fellow owners want to put content here, please reply below.
Buyers Guide and Common Faults
Aside from the usual checks you should perform when buying a used motorcycle, here are some DN-01 specific buyers guide points.
Brakes
As DN-01's have a linked braking system with ABS, with moderate to heavy braking you should hear a mild, high frequency buzzing sound, comparable to the sound of a field of crickets. This is normal.
These motorcycles have a handbrake / parking brake (cool, eh?), this is located by your RIGHT KNEE whilst sat on the bike. It's a latching system, pull it towards you to activate, pull it towards you again to release.
Transmission
The DN-01 transmission, known as the HFT (Human Friendly Transmission) is closer to the torque converter in a traditional automatic gearbox than the CVT system in most scooters. This gearbox converts torque from the engine to the shaft-driven rear wheel by the use of an variable hydraulic piston system where the angle of the "swash" plate controls the gear ratio.
Although the hydraulic system itself is widely regarded as being robust and reliable, it's control systems can suffer from old age. In particular, there are 2 components that can exhibit issues;
Diagnosing faults
Although it's recommended you take your motorcycle to a professional with the correct diagnostic tools, you can read the DTC / fault codes on the DN-01 with the "paperclip trick".
Remove the passenger seat by inserting the key into the side key slot located underneath your LEFT BUTT CHEEK (fnarr) as you sit on the bike (and it would be recommended you remove the drivers seat, this is held in by 2x 10 mm bolts), you will then see a small red plug just behind the fuel tank.
With the ignition off, remove the red plastic cover and gently insert a paperclip (or a small piece of wire) between the pins for the GREEN (with yellow stripe) and BROWN wires - be careful as there's another BROWN wire with a stripe, make sure to use the BROWN only wire.
When the Green/yellow and Brown wires are shorted, you have 2 choices;
Once you have finished reading the fault codes, turn the ignition off, remove the paperclip / wire, then re-assemble everything.
Fault code list
PGM-FI (engine) - 1 part
HFT (Gearbox) - 2 parts
Clearing fault codes
To clear the fault codes, start the above diagnostic procedure, but before you turn the ignition off do one of the following;
My original post:
I'm looking to buy a DN-01 in the coming months and so far I've been unable to find anything that remotely resembles a buyers guide or a list of common faults, both on DN-01.net and Google.
Can any of you lovely folks suggest what I should be looking out for when buying one of these bikes?
Typical questions I have are;
Brakes
Transmission
- The swash plate angle sensor is located near the ground behind the reserve water bottle - being so low this sensor is often subject to poor weather and moisture
- The motor that controls the swash plate angle can suffer from old age and seize up as the magnets disintegrate and stop it from turning
Diagnosing faults
- To read the PGM-FI (engine) fault codes (read from the MIL / check engine light), just turn the ignition on
- To read the HFT (Gearbox) fault codes (read from the gear indicator flashing a horizontal - line), hold down the D / Gear + button whilst turning on the ignition
Fault code list
- To clear PGM-FI (engine) fault codes, remove the paperclip before turning the ignition off
- To clear HFT (Gearbox) fault codes, press S / Gear - once and then D / Gear + once, turn the ignition off and then remove the paperclip
My original post:
- How reliable is the human-friendly transmission? Are the pulley belts known to snap for example?
- Any known mechanical problems such as suspension forks, engine overheating, cutouts?
- Electrical issues? I've spotted one where the bike sometimes doesn't engage drive and requires an ECU reset (battery disconnect) for example
