Oil
Joined
Jan 25, 2012
Messages
299
Saint-Petersburg, Russia
I`ve been recently thinking about changing oil, and asked myself - why we`re not allowed to use car oil instead of motorcycle special? Slippering clutch? Ok, we actually don`t have clutch. What else? High rev engine? Guess we don`t have one too. The max RPM`s are 9000 and my cruising is about 3000/5000 city/highway.
Could it be that this phrase in user manual (about API SG+ and JASO MA) just printed universally like in all other manuals for all other Honda motorcycles?
I`m actually thinking about giving a try to Shell Helix HX7 10W40. It`s pretty cheap, easy to find and has good quality at least on paper http://tdc.ge/wp-content/uploads/2014/03/HELIX_HX7_10W-40.pdf
This is going to turn into a flame war...I can just feel it!!!
Page 11.7 in the service manual lists 5 "symptoms" of unusual "events"
EVERY one, the first cause is likely to be "faulty" engine oil, ie incorrect engine oil.
Attached is an extract from a Honda document re engine oil
GN4 is dino oil
HP4 is semi synth (more for sports bikes running much higher engine speeds)
OK...maybe you haven't had any problems for x years but for a couple of dollars I wouldn't want to risk damaging vital parts cos I put the wrong oil in it.
I just found out that a replacement HFT is nearly $8,000 Gulp!!:eek:
There IS a clutch of sorts in the HFT to enable neutral to drive activation.
Also, regular engine oil is designed to work with SLIDING parts, not cogs and gears. That's why cars have separate engine and transmission oils.
Just my opinion and my dollars worth. For mine, a couple of dollars saving is not worth the risk of getting stuck hundreds of kilometers from home.
Use what you are prepared to pay for.
Good luck.
Cheers
Pete :)
Some info taken from this site
(https://motorcycle.honda.ca/parts-service/honda-genuine-oil-chemicals)
GN4 is dino oil
Good luck.
Cheers
Pete :)
I 'side' with Overthehill when using ONLY specified motorcycle oil in ALL my bikes! I remember a time when I 'used' a 'generic' oil in my Honda car and really screwed things up. Being 'cheap' just does NOT cut it with me especially in a 'unique' machine as the DN-01. (She's SPECIAL!) BUT IF you do decide to go thru with your 'idea' to save a few bucks, please keep us posted to your 'success!'
I have used Wolf's Head Motor Oil 10w40 since new . Change every 4000 miles . Now have 20,000 mile . SG oil was obsolete in 1993 . As long as the oil is NON energy conserving oil . you are good to go .
I've been using 100% 'Amsoil' synthetic oil ever since first oil change. My mileage isn't exceptionally high. As a result, I've only been changing the oil once a year - during winter lay-up. I asked my Honda dealer what to use, he looked it up in a book/manual, and arrived at a suitable substitute.
Mark Zimmerman dispels some of the myths about motorcycles in this recent article. Synthetic Oil is discussed as the 2nd myth.
http://www.motorcyclecruiser.com/5-motorcycle-myths
Since this is my topic, I must to reply. I`ve found recently that the oil I`ve used the past year (Eni i-Ride 10W40) could be found pretty easy from official importer for $6 per liter. With shipping (from other city) it is about $7 per liter which is pretty good. And far better than Motul for $11 per liter (4L canister) Anyway, I`ve previously used Motul 7100 10W40 and after year I can`t say that Eni is worse. It well suits my slow and smooth riding style. And if I buy 20l it will be $4 per liter which I found pretty good. It`s even cheapier than car oil I can found in wallmart. So I think I will stay with this for a while.
OK, here goes - :D
I wouldn't agree that 'faulty' necessarily means incorrect. How incorrect does it have to be to be classified as faulty?
...There IS a clutch of sorts in the HFT to enable neutral to drive activation.
Well I've not stripped a DN-01 engine (unlike most other Honda engines of 30 years ago when I conducted the technical training on them at Honda UK), but unless I'm very much mistaken, there is NO clutch of any sort whatsoever in a DN-01. The fact it can emulate Neutral does not a clutch make. A clutch is a specific device with 2 sets of plates clamped together and the drive to the rear wheel(s) is via the friction between those 2 sets of plates. It is this exact point that is relevant to the use of synthetic oils in motorcycles which are unusual (compared to cars) in mostly using wet clutches. The friction modifiers used in many modern oils (commonly but not uniquely synthetic) might allow an otherwise healthy clutch to slip (apart from Ducatis with rattly dry clutches of course). This is the reason why some oils are not suitable for motorcycle use and a motorcycle specific oil will simply be formulated with fewer such modifiers to allow wet clutches to work as intended.
The DN-01 has no such clutch and hence the friction modifier content is irrelevant.
But motorcycles usually run the same oil in engine and gearbox. It can be argued that separate oils specifically targeted at those different uses would be a better solution, however the statistics back up Honda's claim that it makes sod all difference as engines with common oil in main engine and gearbox experience NO deleterious effects of this sharing. Honda cars with typical separate engine and gearbox housings used to use the same 10W40 in both. Same oil, just not actually shared simply due to the physical design of the engine and gearbox, either side of a dry clutch.
The important points about which oil to use are the specs that Honda quote. This is the oil standard (API, JASO etc) and the viscosity (how thick it is). Both are crucial. Honda quote an oil standard that must be met - or exceeded. That last is important since oil technology progresses and standards get superseded. Honda are just saying, as long as it's at least this good, then it's ok. You can use oil of a lower standard if you want, it's up to you. Really. But if you have an oil related problem, Honda won't help. Use the correct oil as specified and Honda's warranty holds. You could argue that when the bike's out of warranty it doesn't matter, but if Honda decided the bike needs that standard of oil to work as intended, that requirement will not diminish over time and let's be honest, Honda know quite a lot about engine design and lubrication requirements and ain't gonna recommend junk and they don't make oil (i.e. they're not an oil company and are not trying to coerce users into using their oil) so what they recommend is worth following.
Then there's the viscosity. In the Training Schools we had a hard time convincing dealers to not use and recommend 20W50 (a common oil available at the time). This thicker oil is NOT to be used at the average ambient temperature of the UK. In the Arizona desert, maybe. Cleethorpes - probably not. Testing (by Castrol I seem to remember) showed that at low temperatures, the thicker oil could take 30 seconds to reach the cam, after engine start. That's a long time for the cam to be running on just what's left from the last run. In the UK, 10W40 was the correct viscosity.
Nowadays, Honda have mostly lowered that to 10W30, probably sometimes with the same engine for which they previously recommended 10W40. The fact is now that oils have improved and even at high temperatures, a 10W30 oil can still maintain the required film over the important components and since it is actually thinner, there's less drag so more power and better MPG, both of which have become increasingly important.
So the use of 10W40 as opposed to 10W30 will not damage the engine. After all, at lower temperatures, they'll both have the same viscosity. It's just that when the engine's up to normal operating temperature the latter will end up a bit thinner. So back to the DN-01s HFT troubleshooting chart, there's no way those problems apparently caused by 'faulty oil' have anything to do with the use of 10W40 instead of 10W30.
So as long as an oil meets or exceeds the (API, JASO etc) standard specified by Honda and is of suitable viscosity, you're golden. Doesn't matter whose oil it is and in the case of the DN-01, car, motorcycle, synthetic or otherwise shouldn't affect it either. Would I use 10W40? Yes. I use that (Castrol motorcycle synthetic, I forget the name) in all my bikes and it is indeed the viscosity recommended by Honda for most of them. However I have no qualms using it in the more modern ones for which 10W30 is recommended. Once my DN-01 is complete it will also run on Castrol 10W40 synthetic and I am 100% confident it will NOT cause any problems.
Solenoid, not clutch. Which makes the oil flow to different holes.
There IS clutch. The almost normal clutch, with plates etc.
https://www.partzilla.com/catalog/honda/motorcycle/2009/nsa700a-a-dn-01/clutch
Page 2.1 and later in Service Manual.
The only difference that the default mode of normal clutch is "engaged" and you apply force to clutch lever to disengage it. On DN-01 it`s more like centrifugal clutch which is "disengaged" by default. And there is oil pressure from transmission pump side which makes it to engage.
I always have a few liters of high-performance oil here for my race bike. can i put it in the dino too? you can see the specification in the photo.
I would be VERY careful what I put in your Dino as for oil. The HFT is unique so high performance oil just 'might' be a little 'too slippery' for the HFT to work properly OR it just might 'really' screw things up requiring a tear down. For my own piece of mind, I would use Honda recommended oil!
Always use motorcycle oil, not car oil. The DN-01 has an automatic wet clutch, very similar to a "normal" clutch, which, I believe, requires additives that car oil does not or may not have, particularly in fully synthetic oil, which is a lot slippier.
I have used a fully synthetic 10W-40 motorcycle oil for all oil changes, and it works fine.
I ordered original honda oil, with release as in the manual
This thread has prompted me to read section 2 of the FSM (factory service manual) in order clarify just what's happening in this HFT while we're riding it. A long time ago, 35-45 years, I used to work on Case-IH farm machinery. Their then new axial flow harvesters came with this same type of constantly variable transmission, so I was familiar with the concept when the Dino was introduced. In fact, it was because of this unique motorcycle transmission that I went and bought a Dino a year ago. It would be good for all owners to read that section of the FSM to learn of 1. the centrifugal clutch; 2. the N/D clutch and 3. the lock-up mechanism which we feel kick in at about 80kph/50mph.
The N/D clutch, being a wet multi plate clutch as BobF says, is shown in reply 10. It requires Jaso MA spec oil for motorcycles with wet clutches. Car oils can have 'friction modifiers' because they don't have a wet clutch fed by engine oil, unlike most bikes. Friction modifiers may/will cause the N/D clutch to slip and require replacement.
