Jonbirch
Hi All
Can anyone please recommend an OBD diagnostic scanner for the DN-01 ?
thanks - Jon
thanks - Jon
This would be a SMART move!Jon, re-reading your post and that you just got the bike from a Honda you should perhaps take it back. Does it come with any warranty from the dealer?
I had the same issue for a while I took it to a garage they found the engine oil sensor was not earthed so it look like no oil was in the engine hope this helpsNo we can't. The only diagnostic connector is a red one under the seat. Use the detailed procedure in the FSM.
What's the problem with the bike?
My efforts in diagnosis from reply 38.
Buyers guide / common faults?
HI everyone. I'm a brand new owner of DN-01 and also (unfortunately) the owner of new PROBLEM. From time to time I can't start the engine - Key turned on. Ignition registering that bike was in gear, or at least not in neutral, the "-" flashes to indicate a failure (4 slow, 5 faster). I was lucky...www.dn-01.net
