Hi - Is that display permanently showing, with the D, S and 8? If there's a code to be seen, it's after the "reboot" of the dash, the centre bar of the 8 will flash a bit like morse code - short flashes and long flashes that repeat. That's what a code should look like. Always keep the kill switch in the "On" position.
YesterdayHi - Is that display permanently showing, with the D, S and 8? If there's a code to be seen, it's after the "reboot" of the dash, the centre bar of the 8 will flash a bit like morse code - short flashes and long flashes that repeat. That's what a code should look like. Always keep the kill switch in the "On" position.
yesterday the DS8 stayed on…today the DS8 went away and the flashing dash appeared and remained flashing at about one second intervals continuously the display is the same with kill switch on or off I took a video but I can’t figure out how to share it on this siteHi - Is that display permanently showing, with the D, S and 8? If there's a code to be seen, it's after the "reboot" of the dash, the centre bar of the 8 will flash a bit like morse code - short flashes and long flashes that repeat. That's what a code should look like. Always keep the kill switch in the "On" position.
It’s all one second flashes with no breaks or patterns I ran the video for thirty secondsRather than uploading a video, you should be able to count the different short duration and long duration flashing "-"
From a previous post on this site: "Codes are flashed out with blocks of ten in long (1~ second) flashes and blocks of 1 in short (under half a second) flashes, for example two long flashes followed by six short flashes would be a fault code of 26."
Double-check - are you sure that the kill switch is set to "ON"?It’s all one second flashes with no breaks or patterns I ran the video for thirty seconds
OK. What are the symptoms? Does the engine run at all? If not, it may need an HFT reset.
Engine runs perfectOK. What are the symptoms? Does the engine run at all? If not, it may need an HFT reset.
CODES
26-1 Swash Plate Control Motor. Manual page number - 11-97
45-1 Neutral Oil Pressure Switch. Manual page number - 11-106
STEPS EXECUTED AS STATED BY DEALER
Oil Pressure Inspection. Manual Section. Lubrication. Pages 5-5
Fuel System (PGM-FI). FI/IGN/PUMP RELAY Inspection Manual Section. Fuel System. Pages 6-68
ECM Removal/Installation. Manual Section. Fuel System. Pages . 6-68 (This is the new part I bought direct from Japan because unavailable in USA)
ECM Power/Ground Line Inspection. Manual Section. Fuel System Section. Pages 6-69
Sensor Power Line Inspection. Manual Section. Fuel System Section. Pages 6-69
FI/IGN/Pump Relay Inspection 1. Manual Section. Fuel System Section. Pages 6-70
FI/IGN/Pump Relay Inspection 2. Manual Section. Fuel System Section. Pages 6-70
HFT Initialization (TCM RESET). Manual Section. HFT. Pages 11-93
Swash Plate Control Motor Removal/Inspection. Manual Section. HFT. Pages 11-97, 11-98
Swash Plate Angle Sensor Inspection/Removal/Installation. Manual Section. HFT. Pages 11-99,11-100, 11-101
Swash Plate Angle Sensor Shaft Removal/Installation. Manual Section. HFT. Pages 11-101, 11-102
EOT Sensor Removal. Manual Section. HFT. Pages 11-102
Neutral Oil Pressure Switch Removal/Installation. Manual Section. HFT. Pages 11-106 (Dealer Supplied)
Dealer said they did all in the listHave you done what's in reply 7?
